2003 Volkswagen Jetta Car running hot
55,000 MILES • 4 CYL • FWD • MANUAL
CASEYLEE1234
My 2003 VW Jetta 1.8T is running hot. The two fans do not turn on at anytime unless i turn on the A/C. I checked the number 16 fuse and it is good. Where do i start now? The car only has 55,00 miles on it and Ive never had any kind of problems out of it.
Sep 14, 2009 at 2:59 AM
DUBTECH
  • 159 POSTS
The fan switch located on the radiator controls the fans. It may be faulty or a trapped air bubble at the sensor could be giving a false temperature reading.
Sometimes a bad thermostat or a broken water pump will not properly circulate the coolant, this can also give a false temperature reading at the fan switch.
Sep 14, 2009 at 6:27 AM
