Transmission shifting problem
SATURNTECH9
  • 30,869 POSTS
If those are supposed to be codes there is a letter followed by a four digit number.I dont see that with ethier code.
Saturday, April 11th, 2020 AT 5:33 PM (Merged)
EXOVCDS
  • 1,883 POSTS
The 300 is fluid temp sensor related. Are you sure about the second set of numbers?
EXOVCDS
  • 1,883 POSTS
16502 comes up as coolant temp sensor signal too high. Just making sure.
Both from the TCM?
SATURNTECH9
  • 30,869 POSTS
I will check it out but OBD2 codes start with a Letter followed by a four digit number.
SATURNTECH9
  • 30,869 POSTS
Which model jetta do you have?GLI etc?Also what size engine?
CFRMAN
I towed it over to Kona to a specialest but thank you for your help it was a TDI GLS
SATURNTECH9
  • 30,869 POSTS
Your welcome keep me posted on what you find.
