2000 Volkswagen Jetta "Jetta Woes"
165,000 MILES • 4 CYL • 2WD • MANUAL
BRYTNIALLYSSA
'00 vw jetta
list of things wrong with it :
burns oil like crazy
obdII codes -for random cyl2 &4 misfire.
shakes when idling (feels kinda like a tactor)
Major loss of power (1st gear to get up a hill )
previously fixed coil pack and spark plugs and wires only 3 months ish old. tested and are still working?
Also it had been coming up with a pre cat 02 sensor i changed that and nothing happened... now it says that there is no activity.... is there something else i had to do other than plug it in ?
any ideas of what could be going wrong?
thanks for any input!
Mar 4, 2010 at 11:08 PM
JIGGERYPOKERY
  • 7 POSTS
could it be that two of your plug wires are mixed?
My 99 was running roughly, but not terribly (I was working on it only for another problem -a hesitation/bogging-down on acceleration), when I noticed that two of the wires were reversed. this fixed the actual slight roughness, AND the ODB saying that (just) one cylinder was misfiring from time-to-time.
When I first noticed the mixup, I had to check the shop manual twenty times, then went online for another diagram just to be sure.
Sep 10, 2010 at 5:06 PM
