Driving home from school I struck a small bump and the car shut off this happened several times but the car would start up again. The last time however she would not start. Their is spark and fuel going to her. I replaced coil, relays, rotor button and cap. I have searched for broken wires but have found none. Could you please help me with this problem?
A poor student
SPONSORED LINKS
Monday, November 10th, 2008 AT 7:29 AM
MECHANIC
Is it a blue snapping spark and correct fuel pressure
To start this of-check the fuel pressure and comeback with the readings, we go from here
Tuesday, December 20th, 2016 AT 11:51 AM
FHOWLETT
MEMBER
The fuel pressure checked by mechanic was 3 bars. I don't know what that means but he said it was good.
SPONSORED LINKS
MECHANIC
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
FHOWLETT
MEMBER
Sorry about that. That is what we did do and on every plug their was a good blue spark. Somebody mentioned a fuel pressure regulator. Could this be the problem?
MECHANIC
Check the fuel pressure regulator its job is to regulate the pressure-check if the cylinders are getting fuel if not -there's no injection pulses or fuel pressure is too low-
SPONSORED LINKS
FHOWLETT
MEMBER
Sorry I never got back to you until now. Even though I was getting good spark to the plugs, it turns out my problem was the ignition switch. Thanks for all your help.
