1997 Volkswagen Jetta Fuse for cruise control
1997 VOLKSWAGEN JETTA
TECH1219
Electrical problem
1997 Volkswagen Jetta 4 cyl Two Wheel Drive Automatic
I have a 97 VW Jetta whose cruise control doesn't work. Just bought it used and am think its just the fuse. Can anyone please tell me exactly where its located. I saw the diagram but didn't specify exactly where its located. Thanks.
Sep 24, 2009 at 3:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check to see if your brake lamps work
Sep 24, 2009 at 9:15 PM
TECH1219
Yeah the brake lights work. I believe its a relay. Just wondering which one and where I don't have the manual.
Sep 26, 2009 at 3:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
there is no relay or fuse for the circuit. will have to test the cruise control brake pedal position (BPP) switch, the vehicle speed sensor (VSS) , cruise control vacuum pump and the cruise control switch. may be easier just to use a diagnostic scan tool capable of scanning cruise control systems to pinpoint the culprit.
Sep 26, 2009 at 8:57 PM
TECH1219
Thanks i'll do that. I appreciate the help.
Sep 28, 2009 at 11:14 AM
