1995 Volkswagen Jetta Engine Failure
ANNAMARIA
  • 1995 VOLKSWAGEN JETTA
  • 4 CYL
  • 130,000 MILES
My 1995 Jetta starts but cuts out. I've tried replacing the coil and fuel pump, and cleaned out the fuel tank. I have also replaced the plugs and checked engine compression. It seems okay at 165 PSI per cyl. I have tried fuel injection cleaner in fuel with no help. Check engine light comes on as engine is stalling. I was told it needs an oxygen sensor. Could this be the problem? Any other suggestions would be welcome.
Monday, January 14th, 2008 AT 6:19 PM
  • 31,937 POSTS
Hi there,
The first thing to do is check for set engine fault codes, this will help identify any problem with the engine management system.
Mark (mhpautos)
Monday, January 14th, 2008 AT 9:26 PM
