What you mean they wear like a roler coaster?
Those are quite the large tires but that should cause uneven wear.
Are the tires properly mounted/ rims not bent I hope.
They balanced and the back end aligned?
Sounds like possible bad wheel bearing, trying putting on new tires of a smaller size and see how it goes, if it stops the wear, theres a issue with the tires. If not its not in the tires.
SPONSORED LINKS
Wednesday, August 27th, 2008 AT 9:11 AM
