1995 Volkswagen Golf timing belt.
177,445 MILES • 4 CYL • FWD • MANUAL
ALIIIXRANDALL
my timing belt broke while i was driving it, i did NOT hear any sound or anything to make me think there was damage, it just died. It does have an interference engine. I would like to know if it is worth my time to just replace the belt and see if there was no valve-to-piston damage, or should i go ahead and order a new head?
Oct 2, 2008 at 10:43 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
When a timing belt fails there's no warning or any noise as the valves will bend in a micro second, the damage is done before you even realize that you have a problem. I would fit a new timing belt first and do a comp test, the belt will take less than an hr to fit up to the stage that a comp test can be done. check all comps, you may only have 1 or 2 bent valves and the repair will be cheaper than a new head, but if all comps are down remove the head and get it tested & checked for a viable repair first.
Mark (mhpautos)
Oct 2, 2008 at 5:02 PM
