1994 Volkswagen Golf wont start
RICHARD.BLANKENSHIP1
  • 1994 VOLKSWAGEN GOLF
Engine Mechanical problem
1994 Volkswagen Golf 4 cyl Front Wheel Drive Automatic
I am trying to start my vehicle. When I turn the key the car sounds like it wants to start but yet it does not get the extra ump it needs to turn over. Battery is still good, I drove it two days ago and it started up just fine, now it refuses to start after sitting for a couple days. The only thing that has changed is the temperature out side.
Monday, December 22nd, 2008 AT 7:44 AM
DOCFIXIT
  • 18,828 POSTS
Batterys are greatly effectied by temp. Ability to supply enough amps. Is greatly deminished by temp. Full charge batt at 32 deg will loose 25% at 0 50%or more. So if batt is marginal and or has less the 500CCA rating you will experience slow crank no start.
Monday, December 22nd, 2008 AT 9:20 AM
Related Engine Not Running Content
