1996 Volkswagen Cabriolet car turns over but wont start
SUNEEE2U
  • 1996 VOLKSWAGEN CABRIOLET
  • 4 CYL
  • MANUAL
  • 14,500 MILES
Last year, after letting my cabrio sit 3-4 months out of the winer, my car would turn over, but not start, so I bought a new battery and it still turned over but didnt start. I brought it to a mechanic and it ended up being a fuel pump fuse.
Now, my car has been sitting a month in the really cold weather and is giving me the same problem. It turns over, but will not start. I would like to change the fuel pump fuse but I do not know where it is located. I thought the mechanic said it was under the hood, but if so I have no idea where.
thanks!
Tuesday, January 19th, 2010 AT 11:00 AM
When you turn key On -do you hear the fuel pump come On. If not-do below
You're looking for fuse no.18 20amp in the fuse/relay box-also test or swap the fuel pump relay.
Might also want to check the fuel filter if its clogged
Tuesday, January 19th, 2010 AT 5:04 PM
SUNEEE2U
Where is the fuel pump fuse located? Under the hood or inside the car near the driver's laft knee?
Thursday, January 21st, 2010 AT 3:49 PM
Its located under dash, behind knee bolster at bottom right hand corner. There's 22 miniature fuses at the bottom of the fuse box. You're looking for no.18
Thursday, January 21st, 2010 AT 4:34 PM
