2003 Volkswagen Beetle headlight bulb replacement, right sid
RJFIORINO
  • 2003 VOLKSWAGEN BEETLE
  • 4 CYL
  • 35,500 MILES
Looks hard
Sunday, February 22nd, 2009 AT 5:07 PM
LESLICOX
I own a 2000 Beetle I think they may have slightly changed how you pop out the headlight, but on mine there is a plastic button you must press (hard) and a lever you must pull up to pop out the headlight. That's pretty much it then you just take off the back of the casing and switch out the light bulbs.
I've done this twice with no problems but you do need to exercise some caution as I know people have broken the lever before since it is plastic. When you change out the light bulb clean the glide path of the lever so that it won't be hard to change it the next time.
Tuesday, April 14th, 2009 AT 2:33 PM
