How do you change the lightbulb for headlight? We've tried everything. The high beams work, but the low beam is out on left headlight.
Jul 15, 2009 at 12:26 AM
STEVEW84
✓Experienced Mechanic
There is a lever that you have to pull all the way and the headlight will slide out. If you have never done one then it is a bit of a PITA. My recommendation is to try to clean and lube the slides or take it to a shop.
Jul 16, 2009 at 4:59 AM
