Yes it does get cold in NY. Lived there for 60 years. For you question. Make sure the points are set correctly 0.016 Spark plug gap 0.024 to 0.028 Dwell angle 44 to 50 degrees Check the timing, 1973 and 1974 carburated models is 7 degrees before top dead center. Most likely the timing is off. Have seen it before where the car would start and run ok but when the engione warmed up it would not start.
SPONSORED LINKS
Wednesday, May 26th, 2010 AT 10:57 AM
