can i use a gasket sealer such as RTV, to fix an air leak where the manifold and heads meet?
1963 VOLKSWAGEN BEETLE
63VWGUY
Apr 29, 2008 at 12:44 PM
SQM
  • 6,383 POSTS
You can use a sealer, but it will likely be just a temporary patch.
Good chance it will start to leak again. It depends on the size and the location of the leak it might not seal at all and leak immediately after starting the engine.
The best option is to remove the manifold and replace the gasket.
https://www.2carpros.com/articles/replace-intake-manifold-gasket
Jan 15, 2022 at 11:00 AM
