1963 Volkswagen Beetle intake manifold
63VWGUY
Engine Performance problem
1963 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
can a seal/gasket be used to fix an air leak where the intake manifold and head meets? I can't get it to idle smoothly and suspect an air leak.
Apr 29, 2008 at 11:56 AM
  • 31,937 POSTS
Hi there,
There should be a tin type gasket fitted, to prove a leak, listen around the seal with a length of hose , use it as a stethoscope , you will hear the leak.
Mark (mhpautos)
Apr 29, 2008 at 12:34 PM
