1972 Volkswagen Beetle vacuum hose routing
J.STIEG
  • 361 POSTS
Engine Performance problem
1972 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
I have a 72 VW bug and am not shure where the vacuum lines go. The distributor is advanced and retarted by vacuum. Do you have a diagram?
Jul 27, 2010 at 2:07 AM
  • 31,937 POSTS
Hi there,
thank you for the donation,
This vacuum line is a ported line, that is it is not full manifold vacuum, there will be a vacuum outlet at the bottom of the carby, if it has not been hooked up, the port may have a rubber plug on it, check this out.
mark (mhpautos)
Jul 28, 2010 at 12:44 AM
