Vibration
66,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • AUTOMATIC
JARED FRD
My car is a turbo diesel.
When the car reaches forty km/h and I remove my foot from the accelerator and just let it roll, there is a very strong vibration through the whole car.
It also happens when the car is slowing down without me using the brake, only at forty km/h again.
Once it slows down to around thirty five km/h the vibration goes away.
The vibration also goes away if I put the automatic transmission into neutral, but as soon as I go back into drive it starts again, once again only at forty km/h
Had the tires replaced today, wheels balanced and aligned.
Still happening.
Please help!
Aug 19, 2018 at 9:36 PM
  • 55,746 POSTS
This sounds like the CV axles are getting worn/seized and need to be replaced. Here is a guide to help remove the axles so you can check the CV joints for tightness. (They should move freely)
https://www.2carpros.com/articles/replace-cv-axle
and
https://www.2carpros.com/articles/how-a-cv-joint-works
Cheers, Ken
Aug 21, 2018 at 7:55 AM
JARED FRD
Thank you, I will get onto it ASAP.
Aug 21, 2018 at 9:05 AM
  • 55,746 POSTS
Cheers, Ken
Aug 22, 2018 at 3:09 AM
