Vibration
200,000 MILES • V6 • 2WD • MANUAL
SHAWNBOY31
  • 26 POSTS
When I start out in first gear it shakes and vibrates through every gear, when I shift into different gears and I give it gas it's rough and does not seem to have power like it should. It just started, but it is running rough. When I sit there it seems to be okay, it is not gasping for air or bogging down just when I go to give gas.
Apr 16, 2016 at 11:07 AM
  • 31,937 POSTS
Check fuel pressure and fuel filters, sounds as it may be fuel related problem.
Apr 16, 2016 at 6:04 PM
SHAWNBOY31
  • 26 POSTS
I took to O'Reilly to put it on their computer, they said shows can pos sensor, crank shaft sensor, and lean 1 and 2. I can smell it running rich, its lost power, has a bad vibration when idling like it wants to back fire but cannot. It feels like sitting in a hot rod. When I begin to accelerate it bogs down, but it does not ever die out.
Apr 17, 2016 at 4:05 PM
  • 55,721 POSTS
Its sounds like you may have a compression issue, can you plug the plugs and do a compression test? Also when the engine is cranking over does it sounds normal?
Here is a guide for the compression test.
http://www.2carpros.com/articles/how-to-test-engine-compression
Apr 19, 2016 at 11:34 AM
