Vehicle randomly stalls
120,000 MILES • TURBO • 4WD • MANUAL
NJEKWA
Vehicle had no power going uphill and slow to accelerate. We changed both pressure plates but no change. We then changed clutch plate then now it randomly stalls. This started after changing clutch plate. Changed throttle position sensor but still no improvement. At first revs on the dashboard were random but now does not show revs on the dashboard even when engine is running.
Vehicle also has a history of hard start.
Feb 13, 2018 at 6:55 PM
  • 55,732 POSTS
This sounds like a bad MAF or a clogged catalytic converter. We should start by running the codes to help us confirm the issue.
Please let us know what you find.
Cheers, Ken
Feb 15, 2018 at 3:06 AM
