Vehicle not starting properly
88,000 MILES
BIGBOB1964
I have a 3L diesel Renault Mascot the other day it was showing on the dash light that there was water in the fuel filter and the vehicle would not start. I changed the fuel filter started the vehicle and it started fine. the next morning I went to the vehicle to see if it was still okay vehicle would not start. I got it started with some PC start then it seems to be okay for a few hours but then leaving it for quite sometime it's very difficult to start again. could there be a problem with a non-return valve? the fuel pump seems to be building up for sufficient pressure but it just seems to be starved undercoat diesel. I'm trying to start as soon as I've squirting some Easy Start if I straight up and then it just runs fine.
May 27, 2019 at 11:58 PM
  • 55,649 POSTS
When you changed the filter did you use a new o-ring seal? It sounds like the system is leaking air into the fuel. I would double check your work and make sure the filter is OEM and installed correctly. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
May 29, 2019 at 1:25 PM
