2002 Vauxhall Vectra clutch and dual mass flywheel
2002 VAUXHALL VECTRA
83,000 MILES • 4 CYL • 2WD • MANUAL
CHRIS1881
Hi , i have just had a new clutch and dual mass flywheel fitted to my 2002 2.0dti vauxhall vectra after 83,000 miles ... I have noticed its rather sluggish the clutch isnt slipping anymore but is is not as quick as it used to be ... any ideas ? could the new parts need running in ?
Dec 2, 2008 at 3:48 AM
  • 31,937 POSTS
Hi there,
The clutch should work at 100% straight off, if the battery was disconnected there may be a re learn to do for the ECU and the engine management system,unfortunately i have no data on your cars requirements, a phone call to your local dealer will get that answer, start here.
Mark (mhpautos)
Dec 2, 2008 at 8:11 AM
CHRIS1881
Thanks for that MPHAUTOS ... shortly after asking the question the engin electroncs warning light came on , phoned garage he said what you said basicly . engine management has gone on to an emergency running programme ... thanks
Dec 2, 2008 at 6:42 PM
