Smells problem
2007 Vauxhall Vectra Front Wheel Drive Manual 71000 miles
can you tell me what or how to get intake of air how to find it and repair it
Thursday, February 12th, 2009 AT 7:53 AM
DAVE H
MECHANIC
Hello. Thanks for the donation. Much appreciated
could you go into more detail of what the actual fault is and the repair is you want to carry out?
My code definition for P2296 is :- P2296 Fuel Pressure Regulator Control Circuit High
SPONSORED LINKS
Thursday, February 12th, 2009 AT 10:01 PM
WILLDO
MEMBER
Black smoke coming out of the exhaust
Thursday, February 12th, 2009 AT 11:54 PM
WILLDO
MEMBER
Also losing power on a small hill, hope this helps and apoligise for any inconvienence.
Friday, February 13th, 2009 AT 12:05 AM
DAVE H
MECHANIC
The car should still be under warrenty? And therefore any repairs carried out by non vauxhall dealer would void the warrenty. If the warrenty is not an issue, then remove clean or replace the MAF (mass airflow)sensor located on the air filter casing. You could get a manual from your local library for a diagram?
Saturday, February 14th, 2009 AT 4:53 AM
WILLDO
MEMBER
Can you tell me how to fix it.
SPONSORED LINKS
Saturday, February 14th, 2009 AT 2:40 PM
DAVE H
MECHANIC
Remove clean or replace the MAF (mass airflow)sensor located on the air filter casing. You could get a manual from your local library for a diagram?
