1998 Vauxhall Vectra
ACTIVE1345
  • 1998 VAUXHALL VECTRA
Engine Mechanical problem
1998 Vauxhall Vectra Manual 107850 miles
my car exghust smokes very heavy white every time I start the engine. After a min. Its ok I am really worrying to drive it at trafic.I need help
Tuesday, November 4th, 2008 AT 1:57 PM
  • 31,937 POSTS
HI there,
Blue smoke on start ups usually a sign of leaking valve stem seals, these are in the cylinder head & the head will have to be removed to repair this problem.
Mark (mhpautos)
Tuesday, November 4th, 2008 AT 3:52 PM
ACTIVE1345
Thanks for answer for my question but car smokes white not blue, I think car needs good run but dnt know how many miles I should do to get it back to normal
thanks anyway
Tuesday, November 4th, 2008 AT 6:33 PM
  • 31,937 POSTS
I must be colour blind. Lol White smoke is a sign of coolant in the combustion chamber, are you loosing a bit of coolant? When the engine & exhaust is cold the coolant steam & smoke is more visible, you can get a head test done to prove the combustion chamber leaks, and if not there it will be a leak into the inlet manifold some where, have a look at this.
Mark (mhpautos)
Tuesday, November 4th, 2008 AT 8:34 PM
ACTIVE1345
Hi again
no coolent or oil leaks at all, I cant see any leaks under car.I am checking it daily, evrythings ok I dont know why keep smoking white
thanks
Wednesday, November 5th, 2008 AT 7:04 AM
