2003 Vauxhall Corsa Master Cylinder
MIKEJN35
  • 2003 VAUXHALL CORSA
Brakes problem
2003 Vauxhall Corsa 4 cyl Two Wheel Drive Manual
Could you PLEASE tell me WHERE I find the master cylinder to top up fluids? It is definitely NOT under the bonnet
Sunday, August 9th, 2009 AT 10:17 AM
DAVE H
  • 13,383 POSTS
The Master Cylinder is attached to the brake vacuum booster on the right hand side of firewall. Under the bonnet. On some models the filler is seperate from the cylinder but also mounted on the firewall and attached to the cylinder by brake pipes !. It is definately under the bonnet
Sunday, August 9th, 2009 AT 5:14 PM
