2003 Vauxhall Corsa engine coolant
ZKHONAT
  • 2003 VAUXHALL CORSA
2003 Vauxhall Corsa 87000 miles
where is exactly the engine coolant temperature sensor on a vauxhall corsa 2003. 1.2 L
I have bought a new sensor but doesn't resemble anything I can see on the engine. Doesn the sensor have 1 end made of plastic
Tuesday, December 29th, 2009 AT 12:29 PM
DAVE H
  • 13,383 POSTS
The coolant temp sensor is screwed into the right hand side of the head. You will only be able to see the plasitic part of the old one with wire's going to it. Your local autoparts store will be able to supply a repair manual with instructions on how to replace and diagrams !
Thursday, December 31st, 2009 AT 4:49 AM
