is the clutch cable or not.cannot get into gear.clutch pedal seemed to pop and now cannot use
Mar 13, 2010 at 5:00 AM
DAVE H
✓ASE Certified Mechanic
check the clutch cable at both ends for breaks .. pull on ends to see if the cable comes out in you hand .. it could be the clutch has gone bad .. the bearing could have popped through the springs !!
Mar 14, 2010 at 6:40 AM
