I am losing loads of water. There are no obvious signs of leakage, no patches of water under the car and the pipes are secured. We had the cambelt and water pump replaced and still the same. The oil and the water aren't mixing so it can't be the gasket. Has the pump been replaced correct? What do you suggest? Thanks for your time.
Oct 23, 2009 at 5:14 AM
