1993 Vauxhall Astra overheat loss of water/coolant
1993 VAUXHALL ASTRA
MARIA HASKELL
Engine Cooling problem
1993 Vauxhall Astra 4 cyl Front Wheel Drive Automatic 45.000 miles
Hi there, the other day driving on the motorway I noticed the engine's temperature going right up to 120 degress!!! i was desperate and pulled out on the first safe place i could find. it was lack of water and since then i have to top it up everyday. cant find the leak. so then my husband and I noticed the bonnet inside is full of water marks. is it possible that the water compartment's lid is loose so the water/coolant is evaporating through there when i am driving? and in this case replacing the coolant compartment would do the job? we cant think of anything else. thanks for helping.
Jun 5, 2008 at 1:26 AM
  • 31,937 POSTS
Hi there,
You will have to get the cooling system pressure tested. This will help locate any external coolant leaks, i would also have the engine tested for a head gasket problem as well.
Mark (mhpautos)
Jun 5, 2008 at 10:46 AM
MARIA HASKELL
hi mark,
thanks a lot for that. i have already asked my husband to do it.
Jun 6, 2008 at 4:50 AM
