1999 Vauxhall Astra
CARL-28
  • 1999 VAUXHALL ASTRA
Engine Cooling problem
1999 Vauxhall Astra Manual 110000 miles
my astra keeps drinkin water an not leakin anywere an will over heat some times head gasket fine
Sunday, July 4th, 2010 AT 7:14 AM
DAVE H
  • 13,384 POSTS
Have a pressure test for leaks. Have a compression test to check for headgasket failure. Headgaskets are a common fault on this vehicle
Sunday, July 4th, 2010 AT 7:17 AM
CARL-28
Thanks how do I do that an do you no why my dials start jumpin an then go off an the power steering then they will come on again
Sunday, July 4th, 2010 AT 7:22 AM
DAVE H
  • 13,384 POSTS
You need special tools to do both tests ask a tech to check for you a diagnosis is usually free. Soulds like your alterantor is going bad for the power steering fault
Sunday, July 4th, 2010 AT 7:48 AM
