1998 Vauxhall Astra Overheating
DIPPYSYLV
  • 1998 VAUXHALL ASTRA
  • 6 CYL
  • 77,000 MILES
I have an 'R' reg vauxhall astra that is constantly overheating. I have to top up the water in the radiator every 2-3 days. It quickly overheats and the fan doesn't seem to be coming on at all. Also the heaters inside the car aren't working (except for when I have just topped up the radiator, for about half a day).
Any advice would be gratefully received.
Thanks for reading.
Wednesday, April 8th, 2009 AT 8:31 AM
DAVE H
  • 13,384 POSTS
Replace the engine coolant temperature sensor and ahve a coolant pressure test done to check pump function and also a cylinder compression test to check for faulty headgasket .. most good repair centres will diagnose for free in the hope they get the repair work
Hope this helps .. let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_474.png
Wednesday, April 8th, 2009 AT 10:32 AM
