HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Astra
Engine
Symptoms
Overheat
SPONSORED LINKS
1995 Vauxhall Astra
MUSKETEER_2008
MEMBER
1995 VAUXHALL ASTRA
Engine Cooling problem
1995 Vauxhall Astra Automatic
hiya, I have a vauxhall astra, auto, 1995, when the car is running its ok but when waiting in traffic the temp goes up? Any help? Thank-you Alicia
Thursday, May 28th, 2009 AT 6:57 AM
DAVE H
MECHANIC
Check your radiator fan is working correctly .. check coolant level .. and have a cylinder compression test carried out ...
hope this helps .. let me know
SPONSORED LINKS
Thursday, May 28th, 2009 AT 7:12 PM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
Overheating
Hi I Have An Astra Ls 1.4 1995 Its Overheating A Lot But Not Losing Water But Using Lots And Lots Of Oil Do You Have Any Ideas Please
Asked by
jayne
1995
VAUXHALL ASTRA
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1996 Vauxhall Astra Car Over Heating
Engine Cooling Problem 1996 Vauxhall Astra Front Wheel Drive Manual 13100 Miles Hi, I Bought My Vauxhal Astra Ls 1.4 Last Week And...
Asked by
mendedpuddle
1 ANSWER
1996
VAUXHALL ASTRA
1998 Vauxhall Astra Overheating
I Have An 'r' Reg Vauxhall Astra That Is Constantly Overheating. I Have To Top Up The Water In The Radiator Every 2-3 Days. It Quickly...
Asked by
Dippysylv
1 ANSWER
1998
VAUXHALL ASTRA
2001 Vauxhall Astra Over Heating
Why Does My Astra Over Heat When I Go Over 50 Mph If I Keep It Below 50 Mph Its Fine Also The Air Vents Dont Blow Out Hot Air Any More ...
Asked by
whitewater
1 ANSWER
2001
VAUXHALL ASTRA
Overheating Engine
I Have An R Reg Vauxhall Astra Which Is Over Heating. We Have Removed The Thermostat, The Fan Is Working But The Engine Overheats Really...
Asked by
ionacameron
1 ANSWER
3 IMAGES
1988
VAUXHALL ASTRA
VIEW MORE
SPONSORED LINKS
Cooling System Pressure Test
Online car repair manuals
