Van will run sometimes and sometime not
DUNK73
  • 2002 HONDA ODYSSEY
  • V6
  • 180,000 MILES
The van will crank and run it might go one day or three weeks without quitting, but when it shuts off you can wait about an hour and it will start back up. It is not running hot or anything. No check engine lights.
Friday, July 13th, 2018 AT 6:05 PM
  • 109,755 POSTS
Based on your description, I feel either you are losing spark or fuel. I have to be honest, a bad crankshaft sensor will act this way when they get hot. What I need you to do is check if the engine has spark and fuel when it is refusing to start. Something tells me you will find there is no spark. I will attach links which explain how to check both; however, the first link is related to a crankshaft sensor and how they act when they start going bad.
Read through these and let me know if you have questions.
Here are general directions for replacement if you find it is the problem:
These are the links which show how to check for both spark and fuel. Do this when it refuses to start. Let me know what you find.
Let me know if this helps or if you have questions.
Saturday, July 14th, 2018 AT 7:22 PM
