How do you know if it is a bent valve or if it is a sensor?
191,000 MILES • 4 CYL • 2WD • MANUAL
MAYS0219
Rolled in reverse for about a quarter of a mile but while going in reverse it was in first gear lost all brakes so just started rolling while rolling it backfire very loudly. how do I know if the valves are bent?
Apr 23, 2021 at 4:52 PM
  • 110,248 POSTS
A backfire is usually caused by excessive fuel entering the engine. Take a look through this link:
https://www.2carpros.com/articles/engine-backfires-while-running
Now, is the engine still running? As far as checking for a bent valve, the easiest thing to do is a compression test. If you have a bent valve, it will be stuck open and there will be little to no compression in that cylinder.
Here is a link that shows how it is done:
Let me know what you find or if you have other questions. Also, if you can record it cranking and upload it for me to hear, I should be able to tell you if there is a compression issue.
Apr 24, 2021 at 3:06 PM
