Valve cover torque
JPRIVETTE
  • 1997 TOYOTA COROLLA
  • 1.4L
  • 4 CYL
  • 192,000 MILES
I can't seem to find the valve cover torque for my car. I can find instructions online how to change the gasket, but not what to torque it down to after I'm finished.
Thursday, April 11th, 2019 AT 3:04 PM
  • 109,872 POSTS
Welcome to 2CarPros.
Not a problem. You came to the right place. However, you indicated this as a 1.4L. I believe you meant 1.6L because a 1.4L, to the best of my knowledge, wasn't offered.
With that in mind, here is what I have. Let me know if you need anything else.
Mechanical
Vehicle Engine, Cooling and Exhaust Engine Cylinder Head Assembly Valve Cover Specifications Mechanical
MECHANICAL
Bolts. 5.9 Nm (52 inch lbs.)
Note: Make sure not to over tighten. The torque is in inch pounds and not foot pounds.
Let me know if I can help.
Thursday, April 11th, 2019 AT 6:55 PM
JPRIVETTE
Thanks for your help Joe. Do you happen to know the sequence to use when tightening them back down? BTW, it's actually a 1.8, but thanks to a phone glitch it was entered wrong and I don't know how to change it.
Thursday, April 11th, 2019 AT 8:54 PM
  • 109,872 POSTS
Welcome back:
My manual doesn't provide the sequence. Start in the center and work in a crisscross motion. Snug them all first, and then do the final torque.
I confirmed the torque is the same for the 1.8L.
Let me know if you need anything.
Friday, April 12th, 2019 AT 7:48 PM
