valve cover torque specs?
100,000 MILES • 4 CYL • 4WD • MANUAL
PETERYORK
Do I need to torque the screws on the valve cover after I replace the valve cover gasket? If yes, what would be the proper torque amount? 20 inch pound?
Thanks,
Peter
Nov 11, 2009 at 2:50 PM
  • 110,248 POSTS
The manual doesn't include specs. I imagine it's because there are different types of gasket materials.
If you are using a rubber-type gasket, I would recommend between 50 and 60 inch-pounds. Note I said inch-pounds and not foot pounds.
When you tighten the valve cover, do it in a back and forth sequence starting in the middle of the cover.
I hope this helps. Let me know if you have other questions.
Dec 24, 2020 at 1:35 PM
