Unstable idling and black smoke
140 MILES • 2.0L • 4 CYL • 2WD
MULOLO
1. It produces black smoke and unstable idling.
2. When accelerating an engine check light comes on and when I step on the brakes the engine stops.
What is the cause of that?
Nov 3, 2019 at 3:17 PM
Black smoke is caused by excess fuel in the exhaust. Unstable idle and a flashing check engine light is caused by this as well.
Here is a guide that talks about this:
https://www.2carpros.com/articles/engine-black-smoke
The first step is to check codes. This should tell us which cylinder is the issue. More than likely you have a faulty injector but we need to confirm this first. I would try to refrain from driving it until this is repaired because the flashing light means it is doing damage.
Nov 4, 2019 at 9:08 AM
  • 55,694 POSTS
If I may, this guide can help you get the codes:
Nov 5, 2019 at 6:20 AM
