unbalanced engine
71,500 MILES • 3.9L • V6 • RWD • AUTOMATIC
FULTONMAN
  • 7 POSTS
The last time I had in to the dealer, they told me that the 3.9 L was an unbalanced engine. What does that mean?
Jun 8, 2016 at 10:51 PM
HMAC300
  • 48,601 POSTS
because of the firing order the crankshaft is not in rhythm as engine fires so they balance it with torque converter and harmonic balancer to bring it in tune.
Jun 8, 2016 at 11:06 PM
FULTONMAN
  • 7 POSTS
If the converter and harmonic balancer are acting up, would this create an issue sitting at traffic lights wanting to stall and rough acceleration? Has only happened twice in two months.
Jun 8, 2016 at 11:15 PM
  • 55,711 POSTS
No, if the flywheel or harmonic balancer were the problem it would be constant. It sounds like you have a misfire problem, have you changed the spark plugs recently?
Here is a guide to help you
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Let me know what you find.
Best, Ken
Jun 11, 2016 at 7:08 AM
FULTONMAN
  • 7 POSTS
Hi Ken. Today, the truck ran great until I got Into stop and go traffic. The rpm's dropped down to probably 600. Had to put into neutral. It did not want to accelerate when back in drive. I do believe i heard popping (possibly misfiring of plugs). Ran bad. I pulled in to a gas station and allowed it to idle for ten minutes. Ran great after that. When the Dodge dealer ran the engine analysis in April, they did not seem to believe that the plugs needed to be replaced. I took them at their word. There were no trouble codes either. I gave up years ago working on engines. I would not be surprised if the link you sent to me is the problem. The fact that it would not accelerate and had popping sounds, I would imagine it is a firing issue.
Thanks again
Tom
Jun 11, 2016 at 10:54 AM
  • 55,711 POSTS
It could be the fuel pump pressure issue as well, please check this link for more information
Best, Ken
Jun 11, 2016 at 1:21 PM
HMAC300
  • 48,601 POSTS
you can easily check the harmonic balancer, draw a chalk line across it and the pulleys then start engine and give it a quick rev if chalk line moves on balancer the rubber has broken and weight is just moving on you
Jun 11, 2016 at 11:18 PM
FULTONMAN
  • 7 POSTS
Ken, I found out yesterday that my Dakota has a problem code P0172 "system too rich on bank one". As I think I understand, that is the side that has the number one cylinder in firing order. To me, it makes sense. Correct me if I am wrong, but not enough o2 is mixing with fuel, not enough torque is being produced on the downstroke of the Pistons, this would equate to sluggish / non responsive acceleration, if I have the sensor replaced which is down on the bottom left side of the block, have all vacuum hoses checked and have mass airflow sensor cleaned.......do I have a good chance at this fixing my issue?
Jun 12, 2016 at 9:22 PM
HMAC300
  • 48,601 POSTS
check your fuel pressure with a gauge if it's to rich on onebank then good chance whole bank is running poorly causing your problem. quit trying to overanalyze.
Jun 12, 2016 at 11:42 PM
