2001 Dodge Dakota V8 Four Wheel Drive Automatic
As you will see I am having several issuse with my truck right now. This involves what sounds like a dry bearing. The reason I say that is becuase I work on vacuum cleaners and recognize the sound. It seems to be comming from the passenger side of the engine comparment. It is heard clearly when the truck is started and then turned off. I took off the belt and spun individual components by hand but did not feel any to be stiff or wobbly or anything. What can I do as I can not afford the shop?
SPONSORED LINKS
Thursday, February 18th, 2010 AT 4:08 PM
