Too much transmission fluid
1993 NISSAN PATHFINDER
2,006,000 MILES • 3.0L • 6 CYL • 2WD
MARCUSBENTLEY
How do I get part of the fluid out of the transmission? it has two quarts two much in it.
Mar 9, 2020 at 10:26 AM
  • 110,244 POSTS
If it is over full, there is one of two ways. First, (and chances are this isn't what you want to do) is remove the transmission pan. That will drain approximately 4 quarts out and then you will need to replace the gasket and refill.
Or, you can actually get a vacuum pump to draw fluid out through the dipstick. I've seen people use a manual pump as well as one that is actuated by air pressure.
Let me know if that helps or if you have other questions.
Mar 9, 2020 at 12:43 PM
