automatic transmission service
NISSAN PATHFINDER
MACLION
1999 Pathfinder 3.3 4WD
Recently I feel some jerk between 1st and 2nd gear. I want to exchange transmission fluid and filter by my self.
1.I am not sure if it has filter: our local dealer said: no filter at all; while I can find filter here
it make me confused.
2. Is that good to add some transmission conditioner?
3. Is that enough to follow these steps
http://www.2carpros.com/how_to/transmission_service.htm
or there are some tricks?
Apr 8, 2007 at 1:44 AM
What is this an Auto or Manual tranny-if its a Manual you don't-now an automatic-every one of them needs filtering-therefore it should have a filter.
Don't be putting anything it in other than the correct type of fluid-doing so can make things worst.Plus I don't believe in them.
If its manual find the drain plug -drain it plug it back up now go find the fill plug remove it-fill it with the correct typr gear oil.
Apr 8, 2007 at 6:04 AM
