Turns over, no spark after replacing starter
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
KG4OGF
Son's truck had bad starter (would not do anything) and he changed it. Now it turns over fine but will not start. Has fuel and pressure but no spark. Looked for damaged wiring around the starter and battery (main areas we were working) and found nothing.
Two final notes, security light turns off after a second or so of switch being on; also oil and temperature gauge seem not to move.
Jul 14, 2018 at 11:05 AM
  • 55,691 POSTS
The starter is close to the crankshaft angle sensor it sounds like you bumped the connector or damaged the sensor. Here is a guide and video that will show you what to look for:
and
https://youtu.be/sKo7xRWVNqY
Cheers, Ken
Jul 16, 2018 at 5:03 AM
KG4OGF
He changed the sensor and noticed one of the wires going to the plug was bad and that fixed it. Thanks for the help.
Jul 20, 2018 at 10:22 AM
  • 55,691 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Jul 21, 2018 at 5:58 AM
