Okay, I had a bad oil leak so i changed my valve cover gaskets. when removing the spark plug wires i discovered the cylinders were full of oil. so i replaced those gaskets too. i wanted to know if it fixed the leak, so i sprayed degreaser all over the engine and everywhere there was oil, then took my little electric pressure washer and sprayed it all off. Then when i went to start it up, it just cranks but will not start. I have checked and charged the battery, made sure the distributor was dry, checked the air filter, the starter wire. i am lost. i checked to see if the plugs are firing and it is weak but they are.
Aug 27, 2017 at 3:53 PM
