Rear turn signals stopped working
178,678 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
RICH EPPLEY
Both rear turn signals stopped working at the same time.
Feb 23, 2018 at 4:59 AM
MIKE H R
  • 3,094 POSTS
first check the fuses, does the front signal go on and stay on when you use the signal light switch? If the bulb lights check the bulbs on back. Have found that the ground wire usually will create a problem. With the lights off and key out of the ignition switch check the bulb sockets, if they have led lights, turn the bulb around. they only work if in a certain way.
Feb 26, 2018 at 12:38 AM
