tune up,distributor rotor
197,800 MILES
EDDYMAN30
  • 28 POSTS
In the process of changing my cap,rotor and wires and its hard to remove the screw on my rotor because its in a odd position. Would hooking my battery back up and cranking my car change the position? If not what other options do I have?
Apr 20, 2013 at 3:01 AM
just hand crank the motor around to a position you can access the screw
Apr 20, 2013 at 3:09 AM
EDDYMAN30
  • 28 POSTS
How do I do that?
Apr 20, 2013 at 3:16 AM
with the plugs out, grab the belt or the alternator and move the motor till you see the screw
Apr 20, 2013 at 3:38 AM
EDDYMAN30
  • 28 POSTS
Is there any way I can do it without removing the plugs?
Apr 20, 2013 at 3:41 AM
