VALVE JOB-RADIATOR-BURNING OIL
TOYOTA CAMRY
DANKLIBRA
  • 7 POSTS
mechanic recently "replaced exhaust valves" entailed: machine head; oil change; replace cat convert; head gasket set; air filter; timing belt; spark plugs; timing cover gasket; dist rotor; dist cap; spark plug wires; oxygen sensor; cat cat converter; ant coolant; oil filter/oil. I have had back for about 1000 miles; about 2 weeks; in this time i have had to add TEN quarts of oil; and other day stop and go i began to run at high temp almost in red; added "stop leak" for radiator as i noticed fluid on inner rim but none under vehicle; since then the smoke billows out during stops; engine temp is little high; and although no fluid under vehicle and radiator and overflow tank were full; i checked after about 200 miles of adding stop leak and fluid spewed throughout engine; even though temps not hitting red when stopped it begins to billow out from hood; i have to add oil everyday; and notice alot of smoke from exhaust while driving; specifically between shifts. i cannot afford anymore work; and although i needed the engine work i never had radiator issue until now. Additionally even though i was using alot of oil before the work; I never used as much as the car needs now; and the car didn't smoke like it is now, I can tell you one of the plugs was not firing; he said it was running on 3 cyl instead of 4; the only plus side is i went from 17 mpg of gas to 37 mpg. Is there a simple fix for the issue I am now having; mechanic not yet informed of most recent radiator issue; but now saying that the extreme smoke may be pistons; additional 1400$ work, also not alot of oil under car; but there is a small leak in oil pan; however that was there before the repair; and once again the car did not take as much oil nor coolant as it is requiring since the repair. any suggestions. no money left :(
Nov 18, 2007 at 10:01 PM
Why don't you have the mechanic perform a wet and dry compression check. Then followed with a leakdown and vacuum check.
This will determine where the oil is leaking thru. Got this funny feeling the combustion chamber is not sealed properly. Coolant could be also entering the C/C. causing it to rise in temperature.
Nov 18, 2007 at 10:26 PM
