Hard to say with out experiencing the first problem. If they fixed it then and you had no problem with it you well jobs done, but they should of contacted you with a quote to replace all components then and there, that way you know what you are up for, and they should have advised that they recommend replacing other components because they may fail soon. Most people say yeah sure just a way of making more money, and if they do not and it does fail, well they ripped me off what have they done. Often work shops are between a rock and a hard place. Yes they made a mistake by not advising on further work, so do not be over hard. I do not know what they did for the $1,100.00 bill either.
I would check the ignition on that cylinder it may well be an ignition problem, you can check the coil by swapping a known good one to cylinder four and see if the misfire follows the coil, if so replace the coil. After market coils can be around $60.00 genuine a lot more expensive. Try this and see how you get on.
SPONSORED LINKS
Tuesday, October 3rd, 2017 AT 2:45 AM
