2003 Ford Expedition changing fluid/filter on high mileage=
MATTC
  • 2003 FORD EXPEDITION
  • V8
  • 4WD
  • 110,000 MILES
Is it truth or urban legend that you can ruin a high mileage automatic transmission by changing the fluid, if it has not been changed at regular intervals. Our Expedition shows occasional signs of possible transmission problems (sluggish acceleration, hard downshifting, flashing O/D light). To my knowlege, the fluid has never been changed--and I hear from several people that it may fail completely if I do change the fluid.
Thursday, June 18th, 2009 AT 10:55 PM
  • 109,885 POSTS
There is some truth to the legend. When you replace the fluid, it has a cleaner in it which can cause old clutch plates to slip. However, that doesn't sound like your problem. If the OD light is flashing, it sounds like there is a sensor problem. I would recommend having the computer scanned to determine what is causing the light to come on.
Thursday, June 18th, 2009 AT 11:41 PM
