trunk lid release
130,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CMSERVICE527
trunk does not open with dash control or key pad.
Mar 29, 2017 at 2:44 AM
STEVE W.
  • 15,419 POSTS
It could be a bad fuse, bad relay or a bad release motor.
Check fuse 65 (10A) at the body control module. If it is good -
Test for power on the black wire at pin one on the release motor when you push the dash button, and for ground on the Black wire with white stripe at the release motor.
If those test good it's a bad release motor. If you don't find power on the black wire when the button is pushed it can be the relay in the BCM.
Mar 30, 2017 at 9:28 PM
