Truck was running and then it shut off
200,000 MILES • 5.7L • 4WD • AUTOMATIC
JONES TESS AND JOE
  • 56 POSTS
I tried restarting it. Won't start acts like battery is dead. Anyone have a suggestion?
Dec 6, 2019 at 9:21 AM
94 TRANSAM
  • 680 POSTS
What is "acts like battery is dead"?
Just clicks, Turns over slow?
Let me know, Rich
Dec 6, 2019 at 10:58 AM
JONES TESS AND JOE
  • 56 POSTS
Doesn't click or turn over.
Dec 7, 2019 at 1:58 AM
94 TRANSAM
  • 680 POSTS
First, could I get some history on it? Did this come out of nowhere? Was it acting weird and then this happened?
Second this could be many things so lets check the simple stuff first.
Check the #5 50 amp and #6 40 amp and #7 50 amp fuses in the under hood fuse box.
In the same box, check #17, #21.
It would be a good idea while you are doing this to check all the fuses.
Next, check both battery cables. Make sure they have clean connections and are tight.
Then ohms check both of them with a multi-meter to make sure the cables are good and have good connections to the battery, ground and the starter.
Here is a guide to help you with that if you need it:
And a general guide for starter not working.
Let us know what you find.
Rich
Dec 7, 2019 at 10:31 AM
