Truck wants to shut off when I turn corners and check engine light is on
250,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
LACEY VASQUEZ
  • 8 POSTS
Everytime I turn a corner my truck will act like it going to shut off, it never does but it tries to. I have done all basic things like checking fuel lines fuel pump ect., replaced all those. Could it be the fuel filter maybe? The only thing I haven't checked. I even have new coil packs, spark plugs, fuel injectors and all the connectors too. Also my check engine light on.
Jul 12, 2021 at 3:37 AM
SQM
  • 6,383 POSTS
Does this happen anytime you turn the steering wheel (driving or stationary)?
Do you hear any type of noise when you turn?
Based on this information, I am not sure these guides will help but let's run through them and see if there are things there that you have not tried:
https://www.2carpros.com/articles/engine-stalls
https://www.2carpros.com/articles/stall-at-idle
The next two things we should do are check the codes if your check engine light is on and check the fuel pressure.
There could be several factors for this to happen so let me know what codes you have and we can go from there.
Please let me know.
Jul 12, 2021 at 7:20 AM
LACEY VASQUEZ
  • 8 POSTS
P0174 is the code I'm getting too lean in bank 2.
It doesn't make any noise when I turn and after the turn it corrects itself and starts running fine again. It doesn't always do it when I turn only when I have low fuel it seems like.
Jul 12, 2021 at 9:06 AM
LACEY VASQUEZ
  • 8 POSTS
I have also replaced the throttle body position sensor motor and the idle air control valve and EGR valve.
Jul 12, 2021 at 9:09 AM
LACEY VASQUEZ
  • 8 POSTS
I have also replaced the fuel pump and hoses going to gas tank.
Jul 12, 2021 at 9:11 AM
SQM
  • 6,383 POSTS
Have you got a chance to check for any vacuum leaks on the truck?
Let me know please.
Jul 13, 2021 at 1:13 PM
LACEY VASQUEZ
  • 8 POSTS
It ended up being the PCV hose (previously only changed the valve) was the problem for the turning issue. So that is not happening anymore but I still have a code p0174. Truck was running fine but yesterday my rear passenger Caliper started smoking. Is this related to the code I'm getting?
Jul 27, 2021 at 6:41 PM
SQM
  • 6,383 POSTS
Have you tried clearing the code?
Usually the code does not go away even if the issue is gone, unless the code is cleared.
Here is how to clear the code:
https://youtu.be/ahK_eucFi-k
If you would please open up a new question thread for the caliper issue. I will be more than happy to help.
Jul 27, 2021 at 11:15 PM
